Reduction hubs trying to stop wheel spin..
Caroneten - June 9th, 2011 at 09:04 PM
Hi All
I have a kombi with reduction hubs on it, It has a v6 motor and having major trouble with it being able to break traction at speed as the rear of the
kombi rises, it seems to unload the power when the vehicle hits a bump. Just wondering has anyone else experienced this and if so will weighting the
vehicle be any use?
BJ
ernie norley - June 11th, 2011 at 04:15 PM
Gday caronten. I hag a split in the 80's running twin webered 180b motor it used to break transmissions across the diff housing. after 3 boxes I
swapped over to bay kombi IRS & used a single plate beetle box. It was a totally different car to drive handling around corners improved.bit of
work but well worth the effort
Ernie
Craig Torrens - June 11th, 2011 at 04:21 PM
yep, do the IRS conversion.
68AutoBug - June 11th, 2011 at 08:52 PM
Originally
posted by Caroneten
Hi All
vehicle be any use?
BJ
reduction rear hubs were there because of the low power VW engines...
so
more power means replacing the reduction hubs before something goes BANG....
they were designed for the low powered & low geared VW engines and to carry loads....
You will need to replace the reduction hubs...
either with Swing axle gearbox etc... OR
IRS rear end with CV Joints....
bevelhead - August 28th, 2011 at 08:42 PM
try a johnson no hop kit, counteracts the reduction gears trying to ride up the driven gear
silver - August 29th, 2011 at 06:15 AM
Why would you want to break traction?
11CAB - August 29th, 2011 at 10:26 AM
Is that the old "Gyros" twincab? If so, it's already IRS and has a CV flange on the reduction hubs to go to the 2L kombi box.
bevelhead - August 29th, 2011 at 07:34 PM
Originally
posted by 11CAB
Do you know how they did that? weld flange on to cut down original axle? or use type 1 stub which im led to believe will fit early reduction gear?...
