Hi guys,
As the title says, i need to know if a 1800 clutch and flywheel will work with a 2L bellhousing and starter motor?
Thanks heaps,
Alex.
nope i dont think so
I say yes, the 1800 will work if the 2 litre starter is used with the 2 litre bell housing.
Two replys with two different answers haha.
I'll let you guys know whos right tomorow when I refit the engine. If it doesn't fit i have a 1800 bellhousing here I can use, just don't really
feel like swapping them over.
Alex.
Yep, no one else game enough......
i`m with Matty , but only because i already know the 2l housing will work with the 2l starter on any of the irs kombi boxes
the trick is to use the right quill-shaft
It all went together fine, which suprised me with the mix match of parts i have going on. 1600 box with a bellhousing from a 5speed 80s box, 2L
starter motor, 1800 input shaft, 1800 flywheel and clutch and a 2L engine
Sounds like my gearbox in the Baja...... 1600 crownwheel & pinion in a 2L case, syncro locking diff, 1800 Bellhousing ........ I love how VW made
all the bits inter-changeable......
I was under the impression that 2L starter, bellhousing, flywheel, clutch was a set.
We have 1800 starter, bellhousing, flywheel, clutch. On a 2L box. The 1800 clutch is 215mm yeah?
So is this the box with the loc rite diff Alex ??
Nope, no lock right. I missed out on it.
u can buy mine :-)
Tell me more about this locker, would love one for my van!
i bought mine from a guy up north somewhere, he was meant o send me the porsche type axle flanges with it (but didn`t) i fitted it & ran it for
about 3 months, but it made a crunching noise, so i ripped it out, parked it in the corner of the shed & bought a Pelquin slippery diff from Mr
Rod Penrose
i havn`t yet opened the Lockrite up to see what`s happened with it, but i was told they have a lifetime warantee but not sure how that works
i expect it may have just shred a side gear dog teeth (my guess) so i don`t see it costing much to fix, if the so-called lifetime warantee doesn`t
happen
But still , it`s just sitting here, minding it`s own business, i`ve no need for it, but if you want awesome grip, then these give you exactly thaT
