wire problem on fuel sender
clyve - July 2nd, 2014 at 05:56 PM
Ok re fitti g my sons wiring on 73 squareback
Does anybody have a diagram and which side does the power go on to the fuel guage as one way says full when I know it is not and the other is empty?
I think power comes of the fuse to the guage and the other wire goes to the sender unit in tank! Is that all?
Cheers all
grumble - July 2nd, 2014 at 10:12 PM
Clyve I have a couple of type 3 workshop manuals if you are interested,but basicaly that is how the system is and the wire with the eye terminal goes under one of the screws on the sender to earth.
vlad01 - July 3rd, 2014 at 03:26 PM
Cheers all
yep. iirc when you pop the bulb holder off the back of the gauge, the 2 pegs for the fuel meter, one should have a + next to it, I could be wrong. been a while. That one goes to your power, other goes to the sender.
Good idea to add a ground wire under one of the sender screws returning to the body as the factory never did and a lot of the time there is a bad ground due to the tank being supported by foam under the lip and the tank is painted.
clyve - July 3rd, 2014 at 06:38 PM
Yes all is good so thanks pm me about the owners manuals and cost
grumble - July 3rd, 2014 at 07:54 PM
pM sent
