Greatings all need some help on 73 squreback
Got a slight knock at idle but not at revs?
Any ideas?
Tmi seat covers where to get from?
Petronix dizzy will it fit and worth it?
Thanks all
is it constant knock or erratic?
Constant but goes away when you start to rev it
Looking forward to hearing what the knock is.hope its not serious.
Had a beetle with what sounded like poorly adjusted valves or pinging on acceleration,never realy confirmed what it was,but
when we eventually pulled down the engine,couldn't believe the play on 2 of the big ends.........
in a type 3 check the cooling fan bolt, the one with the belt from the generator. usually has a black plastic dome covering the bolt
yep as per above have you done the tappets what grade oil u using has it been change recently and filter washed
TMI from VVDS in Sydney
Ok thanks for the pointers I will investigate this wet weekend an will be back
Thanks again all
Valves done, much better, going for fan next but genny stuffed anybody go a spare or an alt mod that works, noticed bug gens would fit but shaft for fan.hmm still getting there
