hi guys, i have a 72 fast back im fixing up a little and have noticed my seat tracks are half gone so i need to weld in new ones, where can i get
these, mainly the outer ones.
also will be chasing some drop spindles for ball joint disc front and a way to lower rear.
Your seat rails look OK to me, you just need the rail bushes and pins:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-311-881-213-4
As for drop spindles, they don't really exist for type 3s. The fronts can be reindexed like rears. Do a search for how to lower your type 3, it's
reasonably straight forward.
as per above you need the plastic outer for the runners and the pins
the tracks may need a little straightening
Otherwise all OK
those are the good ones to show which ones i have
So you will have to find a shop or some one who is wrecking Type 3 pre 72 and cut them out
where r u located
Rye Victoria, ive been told to try a nick in canberra and another guy in Geelong
[size=5]ended up making them[/size]
Another supplier I've used for bits & pieces for my '72 Fastback and would recommend - http://www.vwispwest.com/pg116/ Items 62, 63 & 64 bottom left hand corner of schematic
kit available from boris at vvds.... about $120 if i remember correctly
got 1 for the panelvan...... it includes the four runner guides , 2 inner and 2 outer and the pins to hold them in
seats are now perfect....... no wobble and they are so smooth to move
