Vintage Speed exhaust question
penguin - January 9th, 2018 at 07:21 AM
Has anyone got the new Vintage Speed exhaust with heater boxes? I have one being fitted on my Ghia thats in the US, but the stock heater boxes wont fit. The flanges etc dont line up. Wondering if anyone has had the problem and if so, what they did to get around it.
Bizarre - January 9th, 2018 at 05:35 PM
I have looked through the Vintage Speed cattle dog and cant find anything with heater boxes
Do you have a link to the one that is an issue?
vw54 - January 9th, 2018 at 06:54 PM
Chris
you have to do what I did
Get some later model heater boxes without the ally heat sink
Get the BIG diameter J Pipes from VS
Open the seams on the heater boxes and remove the stock j pipe then fit the larger VS pipes
Re crimp the outer skin of the heater boxes together and add some welds for strength
Get flanges for the ends of J Pipes weld and fit to the VS muffler
Works a treat heaters in winter
penguin - January 9th, 2018 at 08:16 PM
Thanks Dave, shall see what the guys in the US can do.
Fossil - January 13th, 2018 at 12:59 PM
I put a VS on my Type3 - article in VWMA a couple of issues back.
I chose to weld flange plates (35mm) onto the heater box "J" pipes and use the standard set up - see pictures.
