hi all new to this forum.
wanted know if anybody has or can you retro fit front and rear bumpers from a early type 3 fastback to a new type 3 fastback.
are the brackets in the same spot as the new version,
also can you get repro's for the type 3
i suggest that you trial fit it up and use a measuring tape as well
It can be done but you will need to fabricate/ modify the brackets. The pre-70 use 2 bolt mounting brackets at front, whereas 70-74 have larger 3 bolt brackets.
