Hi All,
I wonder if anyone recognises this headlight ring. It is from a lucas headlight and it could be the same a Karmann Ghia ring Maybe someone can measure
one to be sure. The inner diammeter of the ring is 183mm across at the front and 198mm in the back. It is 25mm deep. It is also the same profile all
the way around which I think make it different from beetles (or early holdens) which have a bulge in the ring.
Here a couple of pictures.
If it can be identified as a KG ring, I will need one of them.
Thanks in advance, Dino.
hey mate if its lucas its not volkswagen might be mini though.
i was thinking mini as well
Hi Barls and Pod, you guys rock.
I think you have put me onto exactly what I need. I found some repro ones on Ebay that look great and I'll get the measurements checked and all will
be good.
Thank you very much. Dino.
Looks like Austin Healey 3000 headlight ring
Morris Minor headlight rings were also very similar to ghias, I used some on a ghia about 15 years ago when I couldn't find any proper ghia ones.
They would have almost certainly been Lucas, most british cars then followed the 'Prince of Darkness'.
Angus
yes its morris, a lot of ghias have morris h/l buckets welded in as well with those fitted
Don't do it! Those headlight assemblies look absolutely wrong and horrible on a Ghia. Original ones are available from Vicsbahn,well worth the investment. They also show up a lot at swapmeets.
