Full flow oil system on type 3 motor? Where do you tap into the case on a type 3?
Any info would be much appreciated.
Thanks Ben
Same as on a type one, but some mods to the fittings required. Very hard to plumb around the fan housing and rear support bar. Easiest way is to get a Berg kit so it goes together properly.
Where do i get a Berg kit and how much?Thanks matberry
Vintage may get one for you {02 97891777) or order yourself from Gene Berg Ent in the states. http://www.geneberg.com/product_info.php?cPath=2746&products_id=447
Here is a bit of info
http://www.thesamba.com/vw/forum/viewtopic.php?t=225533&highlight=full+fl...
Don't click on the first link on the page though(malware)
Great thread on samba. Prefer the one half way down the page, both lines plumbed into the main oil gallery. I thought the Berg setup was better than those pictured. I've done a few over the years and the best was copper pipe extensions with a flare and gland style fitting. Finding something that suits is time consuming as different fittings are often hard to come by.
Heres what I did to my motor, I went through the fan housing with this one (not enough time, money or patience). Seems to work fin and I do not have
any issues with cooling. I reworked the part of the fan housing I removed by using fibre glass matting (no photos though, I'm too ashamed
The only problem I had by doing it this way was the outlet pipe was the lowest point of the engine. got snagged a couple of times but only whilst
getting the engine in and out.
So dont do it how I did it
Hah looking at the huge pictures I've posted, note the awefull clearancing I did with the top oil pump bolts. Honestly they didn't make a drill bit
big enough in those days.
I was using a 30mm melling oil pump too, never got the dam thing to seal against the case so was always leeking oil. but as the saying goes "an oily
engine is a happy engine
It gets better......
Yes that is black electrical tape sealing the return fitting thread
