rear axle bearing retainers??
deluxe hunter - March 9th, 2009 at 11:14 PM
Are the bearing retainer caps on an early wide 5, type 3 the same as an early beetle?
I have used beetle ones, and it seems the drum is not as hard against the backing plate as I would have imagined.
thanks for the help
vw54 - March 10th, 2009 at 05:42 AM
no there are several different types and they vary in depth to hold the bearing in place
depending on what gearbox you have and also the backing plates will make a difference
