I would love to know what script should be on the boot of my 68 notchback?
There are three pin holes but I have never had a script to know what is correct. I had always thought it should be VW-1600 but would like some
confirmation.
The three pin holes are at 0mm, 110mm and 219mm.
Sounds right. This might help. From Valla a few years back. Later had the "L" on it as well from memory. The TL has pins of O, 85 and 215
approx. Too cold to go back and check now.
DH
Ok that sounds like the script I need then.
Does anybody have one?
I do have a the "VW-1600 TL" badge I could swap for one. The badge pins are different to my boot although I could still use it if needed, cutting
off the TL and drill new holes in the boot, I would rather just get the right one.
