Look what I found on the samba.
Its hot as.
http://www.thesamba.com/vw/classifieds/detail.php?id=1034347
........plenty of those around.
Wow 375+shipping. It can stay there. Lol
I never seen one before?
Looks nice never the less.
But then again the off the shelf price on a vdo speedo for example, here is more than that.
I've had a few of these over the years, usually seen in 73 model Type 3's, i pulled one from one of my cars today actually, and the speedo, not sure what im going to do with them yet....
i had 2 Type 3s both with full consuls and Tachos as well like this
sell it to me for a low low price
I am building my own tacho.
Cant go past a Factory one
not big enough though
not to mention the small 6k rpm range.
Have one in my Notch in the consol.Car for sale in cars for sale.
that wheel looks mad!
so late 70's
There are a few of these tacos at Volkspower
here is mine in progress.
i've had a few of those over the years. my last one was in my 66 fasty. never seen them that price before...
The one in my car is the same as the one for sale on Samba.Mine is as new never realised worth that much.The car is for sale reckon should up the price as it has Taco and centre consol.
hey Vlad....I'm liking the look of your new Tacho in the Type 3 housing!! Very nice mate!!
Scarab (aka: Paul)
yeah I like the work i have done so far. Just waiting on the local engineer to make some spacer plate, which I will wrap around the tacho body to make
spacer tubes. Then the spacer will slip inside the old speedo body.
The spacer will set the depth of the tacho /glass to ensure a tight fit between it and the inner black ring/chrome bezel.
Oh and i have to get the ring chromed. Also awaiting a member here for a donor clock or fuel gauge so i can nik the inner ring as the one i have is
very pitted. The pitting is also sub surface which is very very difficult to fill properly.
So I opted for a better ring.
Then onto a mod/restro of the fuel gauge. I want to get a glass cut from real glass then get Dylan to paint the fuel markings on the gauge face
itself. Eliminating the need for cutting slots in the glass for paint and beveling 45o so the optics
of the back light work. Just easier to paint the gauge face lol.
progress
the first pic is the exploded view on how it will go together. Its the bottom line up of parts. The tacho itself has had the glass and glass retainer
ring sikaflexed to the plastic body
to make it a sealed unit. last remaining thing to get done for this gauge is a re-chrome of the bezel. Note in the 2nd pic the precision dept spacer I
have made from 1.1mm steel sheet.
The speedo behind just needs the spacer to be ground down to precision dept and the speedo to be removed from the chrome bezel, filed down to correct
diameter and that will be ready for assembly.
laughing now
All fitted with the perfect dept. Just need that bezel chromed.
so you'll fit it in the speedo housing in the dash?
I retro-fitted the Australian gauges to my square -- it was quite the effort in rewiring...
yep that is correct. the speedo is the new tacho and the old clock is the new speedo. fuel gauge remains relatively stock expect for the plastic lens
is now real glass and i will reproduce the fuel marking on the fuel gauge face itself
as I don't want the markings on the glass like previously
speedo finished, just needs a good wipe down to remove polyurethane and finger print marks.
wow what a gorgeous piece of engineering. Very proud of
this. Took me several weeks to build this. The longer the better.
Dude, that looks the GOODS. Top job!
Are there any issues with calibation? And I assume you need to use a Hall Effect sesnor (I think that's what they are called)?
its programmable. Either you enter the pulses per km if known or run the self calibration.
yes hall effect is correct.
very cool mate....nice work!!
nice work indeed...so a VDO tacho is that expensive? wouaaaaa better take care of mine/!
its shouldn't be
One happy lil fuel gauge. Yes boys and girls, that is real glass
The fuel meter is out atm. The face of it is refinished and will be going off to get customized numbers and markings.
Also take note of my modified lamp block that goes on the back.(spot the difference from stock) Found out yesterday what I thought was an electrical problem is actually how VW designed the indicator makers on the
gauge.
I was like"what the?" Germans did this? The aussie 72 and 73 type 3s
where the only ones with the correct wiring.
looks real nice mate....cant wait to see all three gauges lined up in the dash!!
Scarab (aka: Paul)
