Hi all, just got this off my uncle, first project car and basically first car i've pulled apart at all. Found some nasty stuff just today that i
haven't taken pics of yet but that will come. Basically the fella who sold it to my uncle decided to fill up a hole with expanding foam before
bogging it. Wanker.
First day, took out seats and trimming. Seats are pretty much in tact, bottom of front seats split at seam... (is this repairable with out re-lining
it?)
Second day took back side panel and did a few other things.
Because of the expanding foam there is rust in the top corner above the vent at the back and above the back door fairly bad, the part where the hinge
is welded to has rusted through and come off. is it possible to just weld a plate in there and then weld the hinge to that plate?
There are a few of these along the edges of these panels:
right hand side, this hinge seems to be ok:
Left hand corner, from inside:
Outside:
Left hand bottom, where the bumper bolts on to:
Just behind the left rear wheel:
Inside front wheel arch:
Left hand corner of the boot:
Other side of that:
Battery area:
Right rear wheel arch:
right side under the panel:
Judging from simply looking around this doesn't seem too bad :S
Battery area i figure is easy, cut and then put a plate down and weld both inside and out.
Hinge area I'm a little less confident about being that i have done very little welding and certainly not on any car,
Boot i am also hazy, as i don't know what it's actually supposed to look like haha
Is it best to overlap the steel when welding? or should i cut to fit and weld from the back and then use filler?
Also do i use the same thickness steel for all?
What is the best way to get rid of the rust along the bit just under the window and other places you can't remove to get to...just pour some rust
remover or converter down there and hope for the best? :S
Any help would be awesome!
Cheers,
Francis
ps... is there a trick to getting the windows out, i took the metal bit out which i figure should have loosened it, but no luck.
the expanding foam was put there by the w#nker at vw common on vw s of the period super bugs lbugs all suffered the same sound deadner treatment it
would seem
on my car being a 1970 model avoided the foam treatment best too remove as much foam as possible alot of poking around to prevent the stuff catching
fire
when you weld asfor the rust you will have too make up some repair patches then start removing the rot and welding them back in work on 1 section at a
time start with the easiest 1st your
skills will improve as
you progress
Thanks for the reply
Yeah it just seems a bit daunting atm, i keep finding more haha. The guy seems to have put some galv plates in at the front and put massive amounts of
sealer behind and on them to keep them in place.
Will post some more pictures when i get paid and can start cutting out the rot
im also new and and doing a 71 square resto, my ones rusted in same places exept hole in roof is only of drivers side and is a big hole im looking for
replacesment sheet metal pannels now or i might just get flat sheet and do it myself keep up with the pictures its good to see someone lese going
through what i am too
:P
removing windows dont touch the chrome moulds leave them in so they dont get damaged you dont take off to remove glass are you going too refit with
same rubber? or new you can buy without chrome to put them back the chrome goes in rubber when rubber is on glass as for removing lay on your back and
push them out with your shoes off using a steady even pressure have someone on the outside to catch the window i hope this makes sense
wow thats grusty as!
very typical of late sb.
oops, already took one of the chrome bits out, oh well ill just get a new one, good thing i had only tried one haha.
well from what ive seen its not as bad as it could be, especially as it was in marburg during the floods and the water came up to about the top of the
wheel arches i believe
you can't buy new "chrome bits" (actually polished and anodized aluminum).
you can only buy plastic (mylar) trim. Shit imho
I just finsihed spraying a 73 square a few weeks back. My windows had to be cut out in the end. The seals were that old and crusted on I couldn't get
them out with out a major chance of cracking the glass. Even when i cut the seals the rubber had bonded some how to the frame via 40 years of sun
exposure or whatever. They were still really hard to pop with no rubber holding them in the frame. Might just be easier to get new ones from ISP west
or similar. Below is a few youtubes of a guy who does a bug window. Same process though.
http://www.youtube.com/watch?v=V_SKoPHF0ac
http://www.youtube.com/watch?v=rm32F6w8x9M
Looks like you've got a bit of work a head of you. Good luck and keep up the pics.
Scratch
where are you located, i just took my widows out of my square last weekend i might be able to come help
sweet, thanks for the info all. will have a look at those clips in the morning and give it a go.
dubnbass thanks for the offer, in Brisbane... stafford if you know the area. Got plenty of ppl in the house to help out (girlfriends bro is a mechanic
and is living here)... just a matter of getting them to work haha... offers of beer should help. If we get stuck will defs let you know
looks like your work space is the same as mine.
first thing i did was throw a coat of paint on the asbestos walls to seal it.
just a thought. love the pics. keep em coming
haha cheers for the thought, but i believe these ones are made out of a concrete paste, pretty dodge though, the timber frame isn't attached to the
concrete supports, just waiting for them to fall on me
i can give you a hand with your windows
im restoring a 70" square and can give you a hand
mines fully stripped to get blasted in a few weeks
im from the goldcoast
thanks for the offer, ill keep it in mind..
i think i need to find a bigger space to work, preferably somewhere that is concreted haha
how much is it costing to get it blasted (sand blasted?)?
if you don't mind me asking
er, i don't believe so. its in the type 3 section
sales
Hi Great pictures I am about to do the same treatment to my fasty TL 70 but do not where to start!!!
