I have found a pair of scatt seats that are listed as for beetle 48-55 & Beetle 56-70, will these tacks suit/fit a 1970 fastie?
most likely yes with scats type 3 seat adapter kit. but I am not 100% sure.
I am sure some else can confirm??
No!
Sorry should have mentioned they are the scatt with adaptor. Have been told fairly easy to modify if needed.
yeah thats how I understood it. Like isn't scat seats universal then you add the appropriate adapter?
pretty sure thats how it works. Its the adaptor i may have to modify.
but you can buy type 3 adapter from scat so why bother?
Because the ones for sale are on ebay with beetle adapters
and your point is?
My 'point' is - he is stating this because the seats come with the adapter described (no option for with or without) - you don't get a option to change from beetle to type 3 - it is how they ordered it. His option is to order separate adapters direct from Scat.
or remove his original seats and modify the original framesto take the scat seats
or run type 3 seats like it was intened
Seats going in fine, minor mod's nothing to serious.
