Hi all, As some of you may know im inthe process of putting my 66 Squareback back together. Can someone explain where the brake fluid resorvior is fitted. My 66 is on a 72 pan so has the dual set up not single. Thanks
up in the bonnet/boot passengers side, back towards the hinges
Thanks mate, but am wondering where and how the hoses enter into the boot area as are inder the fuel tank??
single circuit or twin? Early (single) mounted on the right of the spare wheel well and the hose goes thru the wall and past the beam to the master cylinder.... err i'll just go take a pic of mine!
Ok should have read alll of the first post. answer drill some holes. will take a pic of mine.
