Just a question. Want to Know if any of you guys have fitted Beetle Smoothie rims (wide 5) to your early swing axle type 3's?
Do you need to look out for a particular size or year or have to modify them at all?
I'm wanting to try a set of these If anyone knows of any for sale in good condition especially the stud holes which can get a bit flogged over the
years.
what can I say - I like the look. The beetle smoothie rim seems to be the one to fit the logo-less dome caps with that flush look where it meets the
smooth rim centre.
You might have to change from type 3 stock wheels to beetle stock wheels as the mounting for the hub cap is diffrent, also type 3 grease caps pertrude a fair bit so check that for clearance.
Yeah I can see the mounting of hubcaps is different but that is what is drawing me to the early bug rims. I can see the type three rim and hub cap
retainer clip design are probably a tad more secure but the bug smoothies are ultra smooth.
There is a local wrecker who might be able to get me a set. I'll hit him up and maybe he'll let me buy one to try and refund if it don't fit.
A type3 rim is 15x4.5 with +46 offset
Type1 wide5 rim is 15x4 with +34??? offset
I would think you would not want to go to a narrower rim than standard.
A wider custom set of type1 rims with an offset of about +35-40 would be the way to go IMO.
I have no idea who does custom rims these days.
Non standard wheels are not easy with a 64-68 Aussie type3.
Weren't the very early type 3 wheels smooth anyway?
This link may not help but they do look good.
http://www.thesamba.com/vw/classifieds/detail.php?id=1172589
Gee, never heard of Vee guys hoarding Type 3 rims. :?
Vees that ran drums over the last 20 year used "356 style" slotted rims with a double safety beads. We buy them new because road car sourced rims
are bent on gutters etc and the old wheel have only a single safety bead.
They fit fine.
From the samba
VW Fact #216: 64-65 Type 3s used smooth rims, similar to Beetle rims but with a unique hubcap attachment
