Has anyone recently purchase rubber for their CB.?
There are a couple of guys looking for a suitable tyre to run on their CBs which are close to the original 5.60 X 15 but have a but of an off road
capability. They needs some chunk.
Four years ago I purchased a Dunlop which were made in NZ which did the trick but they are not available now.
Any help with atyre brand or distributor will be appreciated.
Countrybuggybill
Try here http://www.antiquetyres.com.au/tyres.html
I've got those Cooper Sportsmans on mine (not on road yet) but they don't have much 'chunk'...
did they have "winter treads" originally Bill ??
Lee.
I have seen the old Dunlop Winter Treads listed as an option for the original release. Many of them came with BF Goodrich Silvertowns from what I can
see.
Its damn difficult to find something right to fit these days.
Had a look at Antique Tyres website and there is nothing really there with some "meat"
we made our own chunks! LOLs
Hi Bill,
There are two tyres i have seen that are a winter tread and are the corect size.One tyre is called a"Victoria"and the other is"Concord"they boath
have almost the same tread pattern.They are a European tyre,i picked up a set from a swap meet.I dont know who brings them into the country orif they
bring them in anymore.
Regards Craig.
When you gents refer to "winter treads", I must admit I am fully amused.
Since the bulk of continental Australia is much closer than where I live to the equator.......I imagine that only a few of you truly know about
"winter".....and thus the need for "winter treads", meaning snow tires; significant energy (cost) expenditure to heat one's home, and just plain
fighting cold, wet elements for a prolonged period. Where I live that means about five months worth of winter fun. Here we generally call the tires
you are discussing "Mud and Snow" tires, and they often come with a "M & S" designation cast into the sidewall lettering on the tire. Although
mud is likely a more common occurrence in Oz, I do know with the years of drought and the ensuing wildfire danger associated with prolonged arid
conditions, I bet that mud is not often a problem one encounters, even beating around in the bush. Although I know southern Oz cools down a bit during
your "winter", our "winters" don't begin to compare, IMO.
I view Australia as this:
My location @ 40.49N -85.63W ....is roughly the same latitude North as that of Stanley in the northwest Tasmania is South @ 40.45S -145.17W. Actually
Smithton is closer to the same latitude @ 40.50S. I know conditions in Tasmania can be difficult at times, but I doubt many of you really have a good
understanding of "winter".
So, being a "temperate" climate in the middle of a huge continental land mass, we are subject to wide ranging conditions on a year round basis. I am
59 years old and in my lifetime here where I reside in north central Indiana, I have seen temperature variations from about 105 degrees Fahrenheit to
-25 degree Fahrenheit (40.5 Celsius to -31.6 Celsius).
In February of 1978 we had a blizzard here which was one of those once in a hundred years or once in a lifetime events. We had between 15 and 20
inches of snow, winds were blowing in the 50-70 mph range, and temperatures of -25 Fahrenheit. The conditions added up to wind chill values of
approximately -70 Fahrenheit (-56.6 Celsius). I guarantee you, that is damed COLD!!!!
We had drifts of snow as high as 10 feet. I was stranded 90 miles north of my home for one week, and even though I was only a few miles off an
Interstate highway, you couldn't go anywhere because none of the roads were passable, including the Interstate.
Frankly those are conditions when even M&S treads aren't of much use on a vehicle, because of the danger of being out very long in those
conditions unless one is very appropriately dressed to meet the climatic conditions.
I'd rather fry for a while in the Oz sunshine, even without M & S treaded tires.
Regards,
Steve,
I can appreciate your US winter having spent two winters in and around Boston and New Hampshire. We here in Oz are blessed with winters where the
thermometers sit on the right side of zero across most of our big brown land.
Yes, Mud and Snow is probably a more description of what I am looking for the Country Buggy. Problem is getting tyres here 165 ( 5.60) X 15 or similar
with some sort of off road capability.
I have scoured the internet and have even tried to follow through with the brands "Victoria" and "Concord" that CB Craig referred to in this
thread. Still not much luck anywhere.
Will keep trying and someone will have the answer.
Regards,
Bill.
