Carravelle Kombi
tdegens - December 19th, 2017 at 10:51 AM
Oh Dear, Brothers Kombi dropped a valve and it went through his piston. It's a 1991 Carravelle . Is it better to put in a Subi, Recondition the Existing Motor or offload it to someone else? Its got Factory Aircon and all original interior with Captain Seats.
Bizarre - December 19th, 2017 at 12:01 PM
Have a look at this post
Food for thought?
Bayside Garage, Moorrabin
http://forums.kombiclub.com/threads/subaru-conversion.56499/
If the body is good I would save it.
If the studs are good - I would put new heads and P&C's in there
If the body is shot - you will get a fair bit in parts
Andy - December 19th, 2017 at 10:25 PM
As Bizarre said, lots of options. T3's are worth saving and have a growing following, and late models like yours seem the most popular.
Which way you go is up to you, there are pro's/con's for converting or re-building.
If you re-build, have it done properly and you will have a great motor that lasts. If you convert, there are a few places now specialising in it (on in Noosa a few people have used also), so drive in/drive out, they do all the work an compliancing for you.
bushed - December 21st, 2017 at 08:52 PM
real budget fix is a Datto SSS mtr 2 litre dual S U carbs with adaptor plate (was in a bay)
needs sump gasket and muffler and some engine supports ...simple ..
incl alternator (may need1600 Kombi starter) $500
04212 86423
