[SOLD] [FS - NSW] For Sale 1965 Beetle SOLD SOLD n RESOLD
vw54 - December 24th, 2019 at 10:20 AM
Yes it up for sale after 20 years
1965 Orange Smoothie
1600 brand new Engine, Freeway flyer Gearbox, Genuine Porsche Fuchs 15 in Polish Mags, no chrome.
Contact David Birchall 0415-957-030 full description send Email to dbirchall54@gmail.com
$22000.00 or ONO
Sunny Sydney 2210
vw54 - December 30th, 2019 at 07:09 PM
Any Questions answered
hulbyw - January 2nd, 2020 at 10:22 AM
How did you fit the Golf steering wheel? Adapter, Golf steering column or ?
Cheers.....Wayne
vw54 - January 3rd, 2020 at 08:18 AM
Wayne
good question not easy to do. the original inner bonnet section is pressed with indentations to allow the steering column and fuse box to fit. it wont allow the golf column to sit correct and flat under the dash
I cut out a section approx. 300mm x 200mm and welding in flat sheet metal to allow the golf steering column to sit flat against the sheet metal
this also allowed a bigger Type 3 fuse box that uses the indicator, headlight and intermittent washer modules to be fitted and a Audi headlight and hazard flasher switch under the dash, so I don't have any switches of radio on the dash its full plated to fill in the original holes for radio s, speakers n switches etc
So I used the Mark 1 golf column with wiper switch on lever with the outer column housing bolted to the new flat sheet metal and used the outer column tube to run down the original beetle firewall steering tube hole.
I used the lower section off the 65 for the steering box end. I made a stepped bush approx. 200mm long to fit in the golf section and the Beetle section, Both tubes are different IDs and it had to be stepped to give the strength also crossed pinned it into position, and hasn't moved in 20 years
Hope this explains
hulbyw - January 3rd, 2020 at 04:14 PM
Thanks. Impressive work. Photo also answered my question about the speaker mounts. Good luck with the sale
Cheers.... Wayne
vw54 - January 11th, 2020 at 02:01 PM
bump
vw54 - January 20th, 2020 at 03:16 PM
vw54 - January 28th, 2020 at 09:35 AM
vw54 - February 3rd, 2020 at 06:57 PM
vw54 - February 5th, 2020 at 05:24 PM
in VMA this month
vw54 - February 17th, 2020 at 05:09 PM
up
vw54 - February 25th, 2020 at 09:25 AM
boot
vw54 - March 29th, 2020 at 04:53 PM
Going to fit new rebuilt 1600 single port engine soon
christopher - March 29th, 2020 at 08:01 PM
$15,000
vw54 - April 16th, 2020 at 06:46 PM
new 1600 engine fitted and running nice
Price dropped to $29000.00
vw54 - April 23rd, 2020 at 08:20 AM
bump
vw54 - May 2nd, 2020 at 07:54 PM
bump
vw54 - May 14th, 2020 at 05:56 PM
bump
vw54 - May 27th, 2020 at 07:24 PM
mn
vw54 - June 2nd, 2020 at 06:35 PM
value
vw54 - June 8th, 2020 at 07:30 PM
WAITING
vw54 - June 20th, 2020 at 08:31 AM
YEP
christopher - June 29th, 2020 at 12:24 PM
$10,000
vw54 - June 29th, 2020 at 06:56 PM
come 0n your going down
vw54 - July 16th, 2020 at 06:37 PM
hello
vw54 - July 23rd, 2020 at 06:20 PM
karmann141 - July 24th, 2020 at 06:15 PM
Not trying to be rude - but over 2700 people have viewed your ad on this site. If you're serious about trying to sell it, have you considered advertising it on Ebay, Carsales, Gumtree etc?
vw54 - July 30th, 2020 at 07:04 PM
yes
had over 100 enquirers but they all want the car for $100 or so
none have ever owned or driven a VW before or realize the work that has been done
barls - July 31st, 2020 at 12:37 AM
Originally posted by vw54
yes
my offer 3 buttons and a piece of belly button lint
vw54 - August 3rd, 2020 at 08:06 PM
Belly button lint is one million dollars per ounce
Buttons are useless as i wear T Shirts
