T3 Vanagon stalling
Bizarre - August 12th, 2014 at 07:16 PM
Developed an issue where my T3 occasionally stalls at idle.
It has never had a good change in revs between drive and neutral / park.
My other van did. It also developed a similar problem and I changed the bit circled - air flow meter??
Just dont know if it is that bit or the cold weather
Is there somewhere else I can look?
Does anyone have a good 2nd hand air flow meter?
ian.mezz - August 12th, 2014 at 07:40 PM
clean throttle body first , could just be soot around butterfly . not letting correct amount of air in at idle.
ian.mezz - August 12th, 2014 at 07:44 PM
Subaru have a good cleaner .
http://www.youtube.com/watch?v=lZuU7DOuOqM
Bizarre - August 14th, 2014 at 06:02 PM
Borrowed an air flow meter and all is well
Now to get one
nils - August 14th, 2014 at 06:17 PM
good result!
I do most of my trouble shooting on the Samba, the amount of vanagon love over there makes for such a massive knowledge base
Bizarre - August 14th, 2014 at 06:21 PM
hmmm............ never bother much with Samba. Will have to change my ways.
Might have to go back to Brick Yard as well
