LED headlights with no high beam low beam
Jak Rizzo - September 23rd, 2017 at 02:23 PM
I just installed some new headlights https://vintagecarleds.com/shop/7-inch/vc3500-classic-kit/  the difference is amazing, but I now have no high beam low beam option.
With one of the old halogen bulbs still connected I have high beam low beam & the other LED works accordingly, but with both LED's connected it doesn't change.
Is there some type of special relay that is required for our old beetles for new modern lighting to work?
regards
jak
southspark - September 23rd, 2017 at 08:04 PM
Hi Jak
Is it the same if you try the opposite side as well ? Is your headlight wiring standard (brown earth,yellow low beam ,white high beam)?
Regards Paul
Jak Rizzo - September 24th, 2017 at 08:00 AM
yes, Paul, doesn't matter which side , when I swap them over it's the same, put both halogens back in, everything works fine, put both LED bulbs on no high beam or low beam. One halogen, one LED high beam & low beam works on the halogen & LED.
Weird huh?
All the headlight wiring is standard & working perfectly.
This is a video showing what I have, although my bulbs are a slightly newer model
https://www.youtube.com/watch?v=Azcfhf2hQB8
southspark - September 24th, 2017 at 10:57 AM
When you say no high beam or low beam ,is there any light at all with the led plugged in?
what year is your bug ?
Jak Rizzo - September 24th, 2017 at 11:11 AM
yes, the LED bulbs work as headlights (& very well) but you cannot change between high or low beam.
They obviously have the provision for both as when I plug 1 halogen back in, the halogen & the LED change between both high & low beam together as normal
beetle is a 71 Superbug. I have no idea?
barls - September 24th, 2017 at 11:47 AM
could it have something to do with the relay and current draw through it. as in not enough to change the relay.
Jak Rizzo - September 24th, 2017 at 12:04 PM
my initial thoughts were relay related & what you are suggesting makes sense given if 1 LED bulb is plugged in with 1 old halogen bulb the high beam low beam works. but not with both LED bulbs
But , then doesn't that fly in the face of LED's drawing less current?
barls - September 24th, 2017 at 01:40 PM
what I'm saying they may not be drawing enough current for the relay to latch. just like when you change to led blinkers you need to ether put a ballast resistor in line or change the relay.
id shoot them an email and ask about it.
beetleboyjeff - September 24th, 2017 at 01:59 PM
I reckon this is the problem, but I don't know enough to offer a solution
southspark - September 24th, 2017 at 05:28 PM
For all your good intention you blokes just forget any ideas of the relay.The relay latching coil has nothing to do with the actual current going through the main contacts, which alternate between a main supply and the high and low beam. Jak give me a call.
Paul
waltermitty - September 24th, 2017 at 11:36 PM
I recon ts an incompatibility problem with the subi donk 8)
Jak Rizzo - September 25th, 2017 at 07:22 AM
:lol:
the only little dramas with my beetle since 2004 have been vw related:lol:
thanks for all the comments guys, I made a video as well, https://www.youtube.com/watch?v=b2LZbpx7aWk
I hate electrics with a passion
I will call you Paul
thanks
Jak
Jak Rizzo - September 25th, 2017 at 12:19 PM
All solved.
Thomas from Vintage LED who sold me the lights, took me through a few things, turned out (after all these years) there has always been some sort of ignition wire hooked up to the high beam , white wires on the fuse box. This was giving constant power to the lights when the ignition is on, it never showed up for all these years (I don't remember ever touching it in 27 years of ownership) as the halogens take quite a bit of power to illuminate where as the LED bulbs take bugger all power, hence why they were on with the ignition.
Everything now works perfectly, high low beam as well. Now I just have to find where the hell that little blue/black wire goes to.
Car still starts on the button & all the gauges & computer work so no idea at the moment what it does.
thank you again for all your help
vw54 - September 25th, 2017 at 07:30 PM
that's the high beam blue light on the speedo I think comes of the hi beam fuse
southspark - September 25th, 2017 at 10:09 PM
Dave is correct that wire runs off the white high beam wires up to the speedo to the high beam light.
There are no mysteries with electrics just unsolved technical problems !
Jak let us know the night time performance especially the high beam.
Regards Paul
barls - October 7th, 2017 at 09:04 PM
im interested as well jak
Jak Rizzo - October 16th, 2017 at 10:40 AM
I normally don't drive my beetle at night (unless unavoidable) but last night was the first proper drive at night.
Amazing. The term 'night & day' is most applicable. The light is white, not yellow, the low beam is simply amazing , so much so I had to keep checking that it wasn't on high beam to convince myself. No other cars flashed their lights at me so they must not be too bright for oncoming traffic which is good. high beam is over & above what is needed.
My wife has a modern car only 2 years old & I think my beetles lights are better.
I also installed LED brake lights & also a 3rd LED brake light in the rear window. I already had LED indicators
Another bonus is that when you turn the lights on, there is no drop in RPM because of the electrical load has been drastically reduced because of the LED's. I am racing Thursday night so it will be nice to not try & drive fast with candles! with no ugly light bar needed on the front
southspark - October 16th, 2017 at 07:12 PM
Thanks for the feedback Jak.
Paul
