Drilling 36hp flywheel for 8 dowels
HappyDaze - August 16th, 2018 at 06:00 AM
I need to drill a 36hp flywheel for 8 dowels. SPG pattern, 6mm dowels.
Any ideas?
Greg
vwo60 - August 16th, 2018 at 07:56 AM
https://vwparts.aircooled.net/8-Dowel-Pin-Crank-Flywheel-SPG-Drill-Fixture-p/...
I don't know if this fits the 36HP crank but you would need a jig unless you are very good at marking out.
HappyDaze - August 16th, 2018 at 10:45 AM
The only jigs I've found (including that one) are for the bigger dowels. I need to drill holes for 6mm dowels.
Looks like I may have to make one!
vw54 - August 17th, 2018 at 01:55 PM
Greg
I have not seen one so I think you will have to make
vwo60 - August 18th, 2018 at 09:50 PM
Do you have access to a milling machine and dividing head.
HappyDaze - August 19th, 2018 at 06:08 AM
Made a drilling jig, a successfully drilled the 4 extra holes - job done...:yes:
1303Steve - August 19th, 2018 at 06:11 PM
smart man
vw54 - August 19th, 2018 at 06:43 PM
hey Greg What are u building
HappyDaze - August 19th, 2018 at 07:50 PM
A W.W. Okrasa 1300 engine to slip into the black '54, Dave...:smirk:
beetleboyjeff - August 19th, 2018 at 08:47 PM
Very nice
