Bus gearbox issue?
OberonViking - April 15th, 2021 at 07:44 PM
I had a look at to buy a 73 bus today.
It had issues with going into 2nd from 1st or 3rd, and the clutch point is a lot further out than I would like. Could these be linked? Is this a gearbox or clutch about to shit itself? It is a 3 rib gearbox with a 2.0L.
If it is a gearbox issue, what will a replacement cost me?
yasdnil01 - April 15th, 2021 at 08:29 PM
Sounds to me like shift rod bushing and clutch adjustment needed
OberonViking - April 15th, 2021 at 08:44 PM
Thank you, so probably not a major issue then.
yasdnil01 - April 15th, 2021 at 09:33 PM
you will have to crawl under the bus and look for slop
the bus will have at least 2 bushings to deal with one just in front of the gear stick shift rod and another one further back along the shift rod
Also the reverse stop plate under the gear stick will be worn and maybe even the gear stick ball end can have issues as well
Also check the trans shift coupler at the nose cone of the trans for slop and or loose grub screw
yasdnil01 - April 15th, 2021 at 09:45 PM
Or it could be the bush on the hockey stick in the nose cone of the trans
But you will only find that after you pull the trans out
Also there is a bearing in the trans that is made of unobtainium as it an odd size and it's the one bearing that chews it's way into the aluminium
gear box housing and causes problem also
So in short .............welcome to the wonderful world of working on 50 year old dak daks
yasdnil01 - April 15th, 2021 at 10:01 PM
As for the clutch issues
could be a cable just about to let go as some of the wire strand have snapped
to much or not enough sag in Bowden tube at the trans
have a look and see if the earth strap is still connected from body to trans if not the clutch cable becomes the earth strap and that chops them out quick sticks
Maybe not enough lube on the cable and binding up with dirt
Anyhow I could go no, but its now way past my bed time
Best of luck
yasdnil01 - April 18th, 2021 at 08:04 PM
Could also be a bent or broke clutch fork / throw-out bearing or pressure plate had just about failed
engine oil or trans oil leak making a sticky mess also
bushed - April 24th, 2021 at 10:08 AM
3 rib boxes still cheap, get one $350 where 2L ones are $750 plus double if recoed amd more
