Shocks for lowered 1959 Beetle
Purple Martin - February 20th, 2022 at 08:42 AM
My lowered 1959 Beetle needs new shocks so I'm after recommendations please. I'd like shocks which are noticably firmer than stock but not bone-jarring racing.
The front is lowered with a ratchet front beam, currently with normal looking shocks, the shock length at rest is 295mm.
The rear is also lowered (not sure how the previous owner did it??) and currently has adjustable coil-over shocks, the shock length at rest is 315mm.
Thanks!
Bizarre - February 20th, 2022 at 05:35 PM
Ggg
Bizarre - February 20th, 2022 at 05:39 PM
Rod Penrose item 344068
Stupid forum
Purple Martin - February 20th, 2022 at 05:58 PM
They look good for the front, thank you!
What should I do about the rear? I'd like to keep the ride height the same, presumably the coilovers affect the ride height?
Bizarre - February 20th, 2022 at 09:23 PM
Ride height on the rear is determined by the setting of the spring plates.
Ask Rod if he does a shorter rear shock
