Engine Assembly. What Sealants to Use?
hulbyw - March 29th, 2023 at 09:06 AM
I know I could get a lot of different opinions but here goes anyway.
What sealants/Loctite/other do folks use on:-
Case halves
Cylinder studs
Oil gallery plugs
Small case studs (oil cooler etc)
Cylinder head nuts/washers
Cylinder to case (with spacers)
Cheers.........Wayne
vw54 - March 30th, 2023 at 01:47 PM
Sikaflex Grey for the engine works well and excesss washes off with presol
hulbyw - March 30th, 2023 at 05:26 PM
Sikaflex Grey? Any more detail?
vw54 - March 30th, 2023 at 05:47 PM
Try Repco or Super cheap
They have several differnt types or google to see preperties n temp ratigs for the sealant it works good for me
vw54 - March 31st, 2023 at 03:20 AM
I am trying to find the number
vw54 - March 31st, 2023 at 09:16 AM
hulbyw
Try this one its a better product that VVDS have been using for years for engines
vwo60 - March 31st, 2023 at 03:36 PM
Case halves
Cylinder studs
Oil gallery plugs
Loctite 518 for the case halve as it does not stop the bearing crush,
Loctite grey on the barrels
Loctite 577 pipe thread sealant for the plugs and fittings
hulbyw - April 1st, 2023 at 12:34 PM
vwo60 - April 1st, 2023 at 02:16 PM
Make certain all surfaces are cleaned with a good solvent like a lacquer thinners.
