er, I bin looking but can't find
where a the best jacking points for trolley jack, Peach has big sway bar across the underneath of the large rear cross tube so that option is out
& is there a detailed mainainance/repair of semaphores page on the net as my drivers side one has a slightly damaged terminal that works indicator
light on speedo & I dont want to bust it by attempting incorrect fix
also noticed with interest that the 12v conversion on mine involved fitting one of those ceramic resistors used with 8V coils to operate semaphores
& wipers, is this a normal idea?
jack under front gearbox mount & front beam
check on thesamba website for semaphore fix
normal for resister on 12 volt conversions to keep 6 volt componants
thanks very much
