1600 to 1200 gearbox
sgetty - November 17th, 2005 at 06:40 AM
hi all
what flywheel would i use for 1600 motor to 1200 gearbox but want to use 12v starter?
cheers deon
vw54 - November 17th, 2005 at 06:53 AM
Use the 12V 1600 flywheel, but you will have to grind out the bellhousing on the 4 high spots and fit an adaptor bush for the starter shaft
The bush is available from Vintage in Sydney 02-9789-1777 if you need it.
sgetty - November 17th, 2005 at 11:03 AM
thanks man:thumb
the 1600 is out of a kombi will that make a differance?
i have a 1500 box down the back would it be easyer to swap the axles to the shorter ones and use it?
deon
[ Edited on 17-11-2005 by sgetty ]
VWFREAK - November 17th, 2005 at 01:03 PM
I can't remember if you need to chage the thrust bearing aswell. Does anyone else know?
vw54 - November 18th, 2005 at 06:53 AM
Depends on what clutch n pressure plate you have fitted
VWFREAK - November 18th, 2005 at 10:32 AM
So if you use stock 1600 plate etc, do you change the bearing or are you better of using the 1200 plate etc?
