Hi Gus,
Im currently running front callipers from a 73 Super.
Is there a larger calliper you can run?
Ive heard stuff about Talbot - but dont know much about them.
Newt
Sherman sells a front set that apparently have a larger pad size.. I can't tell you how much bigger though.
I tried to buy some Talbot ones a few years ago, they don't seem to be around anymore.
The biggest piston size early Type 3 at 42 mm as opposed to 40 mm and it uses the twin pin pad that is also used on the 72 Superbug.
Same bolt pattern on the type 3 ones Steve?
They are the same bolt pattern as Type 1 calipers, you can pick them easily because they only have one bleed nipple.
Thanks for the tip Steve. It's on the list. The list is long. Common target, give me a job :P
Um, Is talbot a brand or a car.....? Where have I been, under a rock?
Thanks guys,
Are all twin pin of the 42mm variety? (or are some 40mm)
Newt
as steve said, the super beetles have 40mm twin pins.
Do the type 3 calipers offer much more stopping power?
It was one of the 1st things I did on David's car when we bought it, I felt that they bit better. I was going to fit Type 3 rear drums as well but
then I decided to go rear discs instead.
how much bigger are type 3 drums.... lots of people rave about them....?
Quote: |
The front callipers just bolt straight on, no adapters or anything. I'm not sure of the increase in size of the Type 3 rear brakes but its quiet
large and they work well, CT is using them on the rear of his oval, as have many other VW racers.
I've posted these before but this what the pads look like in various Beetle & Type 3 VW callipers
my calipers are out in the sun with the paint drying. I will post photos with the pads in later this week!
beetle front calipers, two pin, two bleeder...
pads
hope that explains... something.
