This is kinda the heart of the project, Subaru WRX EJ 20 motor, some of the things going into it are:
2.5 L crankshaft, 12mm high flow oil pump, KP’s MLS full gasket set (1.2mm thick), Mahle Street Stroker Forged pistons and ring set, ARP Head Stud
kit, Manley H Beam Stroker Connecting Rods, King Race Big end Bearings, King Race Main, Gates Racing Belt kit, Brain Crowler Upgraded shafts, stronger
springs, Retainers etc.., Brian Crowler Adjustable Cam Wheels, WRX parallel fuel rails, 800cc Siemens injectors, injector wiring plug kit, WRX/STI 245
ltr fuel pump, Link Storm G4+ ECU
The transmission was rebuilt in Australia and is Subaru, don’t know the model right now. This is a little project for a 69 bug, hope to have it done
in July ‘15 . The drive train is being handled by AVO Turbo Thailand.
Hopefully I can post some pics throughout the build. I’m 63 and this is replacing the Harley’s as it should be a little easier to drive.
Chalee
Just an update on the motor, it has been around the world more than me. Started in Aussie at a machine shop that I don't have the name of. They did
the block and head machine work. Then we waited about 3 weeks for the big end brg.'s. Then there was the assembly and disassembly to machine the
case to clearenance the rods. Then it was assembly/disassembly to machine the rods back in Aussie to clear the block. Rods were shipped last
week.
Chalee
Just some pic's from my hard drive, haven't figured out how to link to my photobucket.
The pan
Way cooler than a Harley. Great looking car. Looking forward to more pics
Sounds pretty exciting! Look forward to hearing how it all progresses
more pics front suspension
Chalee
body shots
Some more pics of the body, it had extensive rust, so we cut it all out. Still have to replace the doors.
Chalee
New door jams.
Chalee
Some pics of the inter cooler placement, the ac will be on the back side.
Chalee
Subarugears, bet you guys go through some garbage cans.
Chalee
Just some random pics, hopefully I want double post pic's.
Chalee
Hey, interesting air intakes in the sides, but have you thought about the water that might come in inside the body panel?
Quote: |
Some engine parts
Stroker Crank
Block, Shinny places are where it was machined to clear the rods,
Heads ported and polished, with titanium retainers
High flow water pump
1000 cc injectors
Adjustable cam gears
Eagle rods, machined to clear case
New Dash
cables, etc..
ECU
Chalee
Some more front end work, most of the major front end structure is / should be done in the next week, then we start on the rear end.
Engine should be complete later this week.
Front End
Chalee
More Front end work.
Chalee
More front end work, all of it will be tied into the roll cage.
Chalee
Few more pic's
Chalee
more pic's,
Chalee
pics
Well it is progressing slowly but it's still going forward. The major frame mods are done on the front, now fitting the ass end together.
Chalee
More pics, looks like a Subraugear gearbox there.
Chalee
More pic's
Chalee
More pic
More Pic's
