Proper rivet setting tool
Birdman - June 19th, 2016 at 04:35 PM
At great hassle and expense, I have sourced proper NOS black vent windows and vent window frames for my bug.
I am now in the process of ordering the correct tube rivets to assemble the two but I need a rivet setter to do the job.
I have done plenty of research and know there are ways to do it without the correct tool but I don't want to go that way.
So the question is, does anyone have a proper tube rivet setter in Sydney, Wollongong or Newcastle areas?
HappyDaze - June 20th, 2016 at 06:38 AM
Is there an 'Old School' brake/clutch service in your area ? If you can find a 'friendly' person, who has done a bit of brake lining work, you may be able to get them to do the job. Or borrow the correct tool... if they haven't chucked it away.
1303Steve - June 20th, 2016 at 08:32 AM
just use an Allen head bolt & nut
Birdman - June 20th, 2016 at 03:22 PM
I was 100% positive you'd say something like that Steve!
vw54 - June 20th, 2016 at 05:44 PM
use a dolly n hammer and peen it over
1303Steve - June 20th, 2016 at 07:40 PM
well use a black bolt one then
