Help with removal of wiring Sunshine Coast (QLD)
BlasterTheRedBajaBug - January 26th, 2017 at 12:52 PM
Hi All
I need help with removing the wiring in Blaster it is a rats nest and I have absolutely no idea what I am doing.
(PM me if you can help)
vwo60 - January 26th, 2017 at 08:56 PM
Were about are you, I am at Pomona.
BlasterTheRedBajaBug - January 26th, 2017 at 10:07 PM
I am at Bokarina half-way between Maroochydore and Caloundra.
vwo60 - January 27th, 2017 at 01:04 PM
It is a bit far to drive but I can help you sort it out and remove it, do you have a manual.
BlasterTheRedBajaBug - January 29th, 2017 at 02:39 PM
PM sent and no I don't have a manual for beetles' that early
vwo60 - February 1st, 2017 at 02:58 PM
Instead of paying some one, buy a manual and you can learn, my advice. plenty on ebay.
vwsteve - February 2nd, 2017 at 11:36 AM
use masking take and number each joint with the opposing side, just don't get the tape wet or let it fade
BlasterTheRedBajaBug - February 7th, 2017 at 11:48 PM
Would I still need to do this if I brought a new wiring harness???
BlasterTheRedBajaBug - February 11th, 2017 at 10:52 AM
Hi would I still need to do this if I bought a new wiring harness?
