spraying pan
rebel - September 24th, 2013 at 04:52 PM
Im going to spray my type 3 pan,can I use killrust expoxy enamel or am I better to rust convert than two pack
vlad01 - October 6th, 2013 at 07:20 PM
killrust is ok on non automotive applications. I would use> Rust bullet, KBS ,POR15 or if you could get it in Australia> Master series. Rated as the best. Out of whats available here, Rust bullet is said to be the best.
Killrust is solvent based, the others I mentioned are moisture cured, master series is 2 pak
I have used POR15 and will continue to use it till I run out of it and its is tough as all buggery. The adhesion and toughness of POR15 vs killrust is like steel vs dirt.
Craig Torrens - October 6th, 2013 at 09:36 PM
My Killrust pan has out lived the POR15 front beam........but maybe i used the por incorrectly:lol:
vlad01 - October 6th, 2013 at 10:34 PM
probably.
there is a fair bit of particular prep involved with por15, once right its works really good.
kill rust works well if you use the same sort of prep plus kill rust primer.
I find their primer does all the work, works really good but the epoxy is not that durable mechanically. i.e can scratch easy compared to por15.
Also I found killrust not at all chemical resistant nor constant wet resistant. But the primer is resistant to most things. I use the kill rust primer with other paints though with good results.
winning combo. kill rust primer and VHT caliper silver paint, plus caliper clear. :tu: but only works with their silver for some reason?
