Creative Engineering Steering Rack & Wiring Harness HELP!!!
camandten2014 - November 23rd, 2014 at 01:45 PM
Hello! I hope someone can help me!
I have installed a Creative Engineering Steering Rack on my 1958 split window and I am having some issues with one wire in the wiring harness. There are two black & red wires which come from the brake switch - one goes to the fuse box (which I have done) and then the other goes a connector which becomes black/violet that goes to the turn signal switch. However I don't have the typical turn signal switch because I have the CE horn button/indicator/main beam & flasher switch that came with the steering rack.
Does anyone know where this other black/red needs to go???
Cam
camandten2014 - November 23rd, 2014 at 01:52 PM
Here is the wiring diagram...
