How to adjust door height
BlasterTheRedBajaBug - February 10th, 2017 at 09:17 PM
Well I have recently run into a problem... The door doesn't fit properly and rain seeps in. I have adjusted the catch on it up to the furthest most point at which the door still shuts but the door still doesn't fit right, should I space the bottom hinge to bring the door bottom upwards or just get those rain guard things on eBay? would it be a better long term plan to space the bottom of the hinge?
modnrod - February 10th, 2017 at 09:45 PM
Best article I've found, and it helped me a lot.
http://www.hotvws.com/content.php?contentID=73
BlasterTheRedBajaBug - February 10th, 2017 at 10:16 PM
Wow That is most likely the easiest fix ever thanks so much
