pinouts subi
binner - November 18th, 2018 at 05:14 AM
hi,
I've been doing a few conversions from subi engines to vw's. I have only been doing ej22's but have just begun a conversion with a ej 20.
I don't have a wiring diagram for this, only need about 6 wires that I cant figure out from ecu plugs.
Does anyone have an ecu pinout to share, 2000 liberty EJ20 manual non turbo
numbers are
B134 35 pin Blue connector
> #6 pin Red with Blue trace
> #21 pin Red with White trace Rear 02 sensor?
> #20 pin Green and Red trace
B135 28 pin Orange connector
> #28 pin Purple Starter switch?
> #27 pin Purple with Blue trace A/C switch ?
B136 30 pin Green connector
> #21 pin Purple with yellow trace Ground ?
mackaymanx - November 18th, 2018 at 11:43 AM
B134 #6 Idle Air Control Solenoid Valve - Signal 2 - 1-13v - waveform
B134 #21 Rear Oxygen Sensor Heater Signal - 0-1.0v
B134 #20 Idle Air Control Solenoid Valve - Signal 4 - 1-13v - waveform
B135 #28 Starter Switch
B235 #27 A/C switch (Input) +ve
B136 #21 Ground (control Systems)
This is from an EJ251 but I have interchanged looms between the two as they are the same, except manual/auto differences.
binner - November 18th, 2018 at 08:15 PM
^^^^^awesome mate... thank you!!
I actually had that scribbled down from a 25 .... good to see I was on the right track.
binner - February 2nd, 2019 at 09:07 AM
....just got back to this project...
a few more im unsure of....
Orange plug #28 white with black trace
Blue plug #17 Blue with orange trace or maybe brown...cant tell
Blue plug #32 Orange with white trace
thanks in advance
mackaymanx - February 2nd, 2019 at 10:02 AM
B135 Orange #28 starter signal 8-14v cranking (INPUT)
B134 Blue #17 A/C control relay ON:0.5 or less OFF 10-13. this switches the A/C clutch on by EARTHING the relay. (OUTPUT)
B134 Blue #32 something to do with VDC vehicle dynamic control system. Have not seen this on a loom before personally.
Again this is EJ251, I have not addressed colours as Imprezas and Libertys are different but are basically wired the same.
binner - February 2nd, 2019 at 12:45 PM
awesome man...thank you muchly. I was struggling with these ones....
