1303 sti project 325hp+ on the road!! New video 260 klm on autobahn!!
johan84 - February 14th, 2012 at 06:45 AM
hello
i'm johan and from holland and read a lot on this forum
i also have a project of my on busy on it now for 2 years
i have a 1303 from 1972 and have done some mods
but i started with this
http://www.mijnalbum.nl/Foto-PF6MTBD4-D.jpg
http://www.mijnalbum.nl/Foto-JHIXPQV4-D.jpg
front and rear porsche 944 trailing arms
944 disc's and boxter calipers
rear mod to unibail coil overs
porsche G50.03 964 transmission
KEP connection kit a clutch kit
subaru ej207 sti engine 2002 runned 36000miles
custom intercooler inlets
custom wheels 16"steel rims widend front 2,5cm
rear 6,5cm
and much more
http://www.mijnalbum.nl/Foto-XBCHBR44-D.jpg
http://www.mijnalbum.nl/Foto-34IAQFS3-D.jpg
http://www.mijnalbum.nl/Foto-VEG7KVRD-D.jpg
http://www.mijnalbum.nl/Foto-MFWZFLGX-D.jpg
also have a full rollcage and doorbars (removaible)
http://www.mijnalbum.nl/Foto-OS88EQR8-D.jpg
http://www.mijnalbum.nl/Foto-MSJEWWGQ-D.jpg
did al the engine wiring (big job)
http://www.mijnalbum.nl/Foto-SNUTOQX8-D.jpg
custom 3"exhaust magnaflow mufflers
http://www.mijnalbum.nl/Foto-4VQGJ3OU-D.jpg
custom inlets on the front wing hope it will work to let the airflow out off under wings at high speed
http://www.mijnalbum.nl/Foto-MBGFFAUD-D.jpg
intercooler inlets placed the rear windows 15cm inside and airflow is getting out to the original air outlet under the rear window
http://www.mijnalbum.nl/Foto-VFNF34OD-D.jpg
http://www.mijnalbum.nl/Foto-7US3LT4V-D.jpg
http://www.mijnalbum.nl/Foto-W7JCH6BG-D.jpg
i'm now busy to get the body ready for paint
but it is getting slowly i'm also renovating the house
this is how the engine look like now
http://www.mijnalbum.nl/Foto-BNGHK6GM-D.jpg
custom little wing to improve air flow to intercooler
http://www.mijnalbum.nl/Foto-VJN4WCJQ-D.jpg
but i hope i can drive i the second half of this year
i have also some video's on youtube
from the first start
www.youtube.com/watch?v=fae2gHi20fE
johan84 - February 14th, 2012 at 06:48 AM
and a video of the first drive
www.youtube.com/watch?v=L1PKfK_BaWE
pete wood - February 14th, 2012 at 06:07 PM
interesting. keep up the work :tu:
cam070 - February 14th, 2012 at 09:59 PM
Looks like a nice project. Keep the updates coming
johan84 - October 27th, 2013 at 07:03 AM
it is been a long time
but it is almost finished
i have to do some small bit's but i can drive it
so i thought share it here to
the plan was to build a fast beetle with at least 300hp
http://www.mijnalbum.nl/Foto-P33ROSKC-D.jpg
http://www.mijnalbum.nl/Foto-XCPCXH3S-D.jpg
http://www.mijnalbum.nl/Foto-437HRDGX-D.jpg
http://www.mijnalbum.nl/Foto-IR7QO4XE-D.jpg
http://www.mijnalbum.nl/Foto-IFD4NPKX-D.jpg
youtube:
http://youtu.be/-2wilTC5Cs0
http://youtu.be/GrFrrbbncL0
http://youtu.be/fae2gHi20fE
http://youtu.be/L1PKfK_BaWE
car spec:
VW 1303 beetle 1972
engine
2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo
engine is stock
ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models)
ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost
should have at least 325hp+. it is not been on the dyno yet
rev.limit 7800rpm
i can get 120klm (75mph) in second gear ;)
exhaust:
custom made 3" stainless steel with 2 magnaflow 4" mufflers
i'm driving with DB-killers it is now 2 times 2,25"
but it has no influence on the power or spool up of the turbo
but driving without db killers makes it like a rally car sound
there is a youtube link above
gearbox:
porsche 911(964) G50.03 5 speed gearbox incl shifter
that is modified to custom shifting linkage
clutch adapter kit
KEP: adapter kit
sachs stock 911 pressure plate
and high performance 6 puck kep clutch plate
spec can hold up to +/- 850nm
suspension
front: fk-coil overs
944 hubs and brake discs
porsche boxster brembo calipers
custom made steering arms/rods
custom made stabilizer bars(cupstrebe
rear: 944 suspension arms and brake discs
custom made stabilizer bars(cupstrebe)
red9design uniball system
spax coil overs
wheels/rims: steel rims 16inch rear245/45/16 front215/35/16
pre 65 chrome covers
fenders front fully steel: front widened 2,5cm 1 inch
rear widened 6,5cm 2,5inch
fully roll cage incl doorbars
2 gt3 racing seats
4 point belts
omp steering wheel
2002 sti instrument cluster
boost, oil pressure and oil temp gauges.
and much more
i have to do some little things on the interior
and polish the paint
and i need to make a front splitter
because when doing around 200klm (125mph)
it is getting to search on the road a i need to do little
corrections just like in old porsche
when putting a good splitter underneath
i has to do better and i can test it on the autobahn next year
(i'm from holland and live 15klm from the autobahn ;D )
hope you like it
Camo - October 27th, 2013 at 09:56 AM
Wow, your goal was to have a bug with 300hp and you have definitely achieved what you wanted.
Congratulations and you make me want to go down another path and build something similar :(
Be careful driving and enjoy. See if you can drive it around without smiling :lol::lol::lol::lol:
Cheers, Kev
johan84 - October 28th, 2013 at 07:58 AM
Cheers, Kev
thanks!!
yes that smile is very big :lol:
1303Steve - October 28th, 2013 at 05:49 PM
Great build on your car.
Have you weighed the car yet?
johan84 - October 28th, 2013 at 07:49 PM
no not yet
i think between 950 and 1050 kg (2100 and 2300 lbs)
gr johan
johan84 - April 8th, 2014 at 08:49 PM
Made a new vid
Wiht a hd cam
But when i was home again it was on 720p and not on full hd
But still nice to see i think
Next will be on full hd
http://youtu.be/ldYdgGaC22M
It is al most fully done
I bought a kamei spoiler that will be fitted and i have to do an splitter
And then it is 100% ready
1303Steve - April 10th, 2014 at 09:23 PM
Your transmission sounds just like mine. How are you finding the puck clutch?
johan84 - April 10th, 2014 at 10:48 PM
Yes the famous g50 rattle
The puck clutch is very sticky specialy when warm
But with a dragrace it is very good
1303Steve - April 11th, 2014 at 04:09 PM
I'm running a KEP organic disc with one of their lightweight covers, it works well and nearly everyone who drives the car stalls the motor as it can be a bit savage.
So is the puck clutch in or out? Or can you slip it a little?
johan84 - April 11th, 2014 at 04:31 PM
I have the 6 puck kep clutch an oem porsche pressure plate
You can slip it a little
You just have to get used to it
When i drive it for a hole day i have no problem with it
To slip it
But it is more difficult because the pedals are floor mount
matberry - April 11th, 2014 at 08:26 PM
Fantastic build :tu:
johan84 - April 14th, 2014 at 12:44 AM
got new video sprint 0 -200klm
wheelspin in 1 gear and to early to 2 gear but still pretty fast!!
but only the audio is still problem that i need to fix
sorry about that
http://youtu.be/PG10E8_utiI]0 200 klm sprint
and a reaction video of a mate
http://youtu.be/ri5BRdfaQ1s]Reaction video
johan84 - May 9th, 2014 at 06:56 AM
Test video of the custom splitter and kamei spoiler
Also better sound with the new microphone
It is now very stable at higher speeds
Fast drive by video super sound!! Click here
1303Steve - May 9th, 2014 at 11:59 AM
sounds good
vlad01 - May 14th, 2014 at 12:51 PM
Nice!
johan84 - June 11th, 2014 at 09:40 PM
Did a drive on the autobahn to look ho the car is doing on highspeed
En it is very stable
Only de camera do'nt like te little vibrations
My goal 250 klm/h but i did 260 klm/h
http://youtu.be/QQ89wnTK8iQ"]http://youtu.be/QQ89wnTK8iQ
Yogie - June 12th, 2014 at 12:09 PM
Awesome. It does look really stable as well. Did you have anyone trying to catch up to you?
Yogie
johan84 - June 12th, 2014 at 02:50 PM
Yogie
Did not try to look in the rear mirror at the time
Vw nutter - June 12th, 2014 at 09:33 PM
haha thats a great video, looks very fast too!
Nice work!
Pickpocket - July 1st, 2014 at 05:56 PM
4th gear? Sounded that way by the number of times you shifted. Congrats!
johan84 - July 2nd, 2014 at 01:15 AM
5 gear about 6400 rpm rev limit is 7800rpm
