started toput my dash together found that the thin alloy dash wont give me clearance from wiper motor any dash availiable or will i need a fiber glasser to modify mine thought about just spaceing it but looks dicky any ideas
If thats your buggy in your DP, then your dash should look like this
Are you using a 12 or 6 volt wiper set
12 volt but doesnt seem to be much diff other than about 5-10 mm clearance and 5 mm closer together wipers, yes thats my dash but been cut out and alloy plate made up
hahaha. I flipped the photo so it would give you a right hand drive idea of your dash.
But you still have the LHD dash in the buggy anyways.
just move the speedo to the other side of the column and remake the alloy plate.
It will only be the big ass vw speedo causeing the issues.
oil pressure also but ill be able to move that BRILLIANT another angle fixes it cheers
