hay all i have a 62 model bug..
the doors on it have been conveted to one piece glass, i have the glass and the door have been cut for it.. wat do i do about the runers an winder
mec
cheers criddy
If I were You I would have the door welded back to standard and fit normal glass and quarter windows..
they used to come as a kit - glass bailey channel etc...
Most VW shops like Mick Motors VVD etc would be able to sell You the right stuff...
You use the normal regulators... etc...
I don't think any special parts were used apart from the scrapers... outer scraper just went from one end to the other... some went up at the front
and looked better...
you need dual lift regulators out of a later model otherwise the windows will not stay level, they can be a pain in the bottom
