jacks hillclimb, in car footage
cnfabo - February 26th, 2013 at 08:39 AM
hi guys competed on the weekend with the vintage sporting car club of wa at wa's only perminent hillclimb....i was trying a different wheel alignment and bumpsteer setting and seemed to feel pretty good. so here is to vids..
http://www.youtube.com/watch?v=J4sNeWPKiTo
this is my fastest run buy overexposed the settings...
http://www.youtube.com/watch?v=jhSZdiDydU4&feature=youtu.be
cheers...
vassy66T1 - February 26th, 2013 at 09:11 AM
Giving it a red hot go!!
Nice work
Craig Torrens - February 26th, 2013 at 10:32 AM
so is it now dry sumped ? how does the new gbox feel ?
Sides - February 26th, 2013 at 10:43 AM
Nice work Chris - looks like a ton of fun !!!
Just curious - what front settings have you ended up at ???
colin - February 26th, 2013 at 04:44 PM
Thats looks like a real fun track chris,
engine sounds smooth and well tuned.:tu:
Cheers Col
cnfabo - February 26th, 2013 at 06:17 PM
im running zero toe at the front, and in bump i have toe in and toe out on rebound..camber 3.5....
cnfabo - February 26th, 2013 at 06:19 PM
yes dry sumped but the oil pressure stayed around the 40psi even up the revs??
the gearbox felt wicked, feels like i have more hp with the 4.375 and slightly closer 3rd and 4th "did not use 4th"
dangerous - February 26th, 2013 at 06:44 PM
Sounds great Chris!
benny_acko - February 26th, 2013 at 07:54 PM
Looks great mate..and like a ton of fun!
Craig Torrens - February 26th, 2013 at 08:55 PM
you certainly managed to change a lot in the off season !....thanks for posting the vids :tu:
Gracey - February 26th, 2013 at 09:46 PM
Sounds great Chris, thanks for posting.
cnfabo - February 26th, 2013 at 10:29 PM
No worries guys, when I get the chance I'll post a few pics of the dry sump tank etc
humpty - February 27th, 2013 at 12:39 AM
Good to see the shifter worked out for you Chris.
dangerous - February 27th, 2013 at 10:30 AM
I am pretty sure those CB dry sump pumps only have 21mm pressure gears.
It would be nice to see a little more pressure,
but realistically is is probably more than enough.(or else the rods would be all over the road by now).
It may just need relief valve adjustment, or it may be all the pump can deliver..
cnfabo - February 27th, 2013 at 07:11 PM
but realistically is is probably more than enough.(or else the rods would be all over the road by now). Gulp!
I might look into getting some more pressure to be safe
Craig Torrens - February 27th, 2013 at 07:23 PM
did it have more pressure before the change ?
colin - February 27th, 2013 at 07:46 PM
I would like to see a little more pressure.
Approx 60psi at 7000 plus rpm
Cheers Col
cnfabo - February 28th, 2013 at 01:35 AM
Yes it had more pressure. Better get it sorted before my next race in 2 weeks
Craig Torrens - March 22nd, 2013 at 12:00 PM
Any updates on your oil pressure problem ?
cnfabo - March 22nd, 2013 at 09:22 PM
Installed adjustable pressure dooby wacky thingy bobby.have not checked warm pressure yet, fired her up the other day and had 80psi and had heaps more adjustment left in it.
colin - March 23rd, 2013 at 02:11 PM
What product did you purchase?.
Cheers Col
cnfabo - March 23rd, 2013 at 02:35 PM
Just one of the adjustable pressure relief valves for the case. Not going to fuck around with a external ones considering of done all that plumbing , not changing it now!!
