Adjustable koni owners
Aussie Dubbin - June 28th, 2013 at 12:13 AM
How big is the foam/rubber spacer meant to be? I just put the fronts in and it's about two inches long or more... Is that right, or do I leave that bit out?
Cheers if u can help
1303Steve - June 28th, 2013 at 08:29 AM
Thats the bump stop, it has to be there otherwise the adjusting tips could hit. I'm not sure of the correct stock length but they can be cut shorter for lowered cars.
Aussie Dubbin - June 28th, 2013 at 10:37 AM
Cheers mate
Looks really long and what you have said makes sense. I'll try as is and go from there.
