Gearbox advice
turboboy - July 19th, 2014 at 06:46 PM
Any advice on the gearbox I plan to get done
It's going in my Buggy , aprox 680kg , 26inch tires
6500rpm
Pro 091 Bus VW 4.57 R/P 3.11-1.93-1.22-.82 Weddle 1-4 gears
Bus to Bug Housing
LSD Diff
930 Flanges
002 Bell Housing
Type 1 930 Axle Stubs
300 M Axles 15 5/8
Solid Mounts
(4) 930 CV Joints
Rich
:tu:
HappyDaze - July 19th, 2014 at 07:14 PM
Dangerous :tu:
andrewmurphy - July 20th, 2014 at 07:36 AM
Dangerous :tu:
turboboy - July 20th, 2014 at 11:49 AM
Hello Dave , I know you are out there.
Any comments/ advice
dangerous - July 21st, 2014 at 08:34 AM
Is it a street car or race?
How much HP?
If it is race, get a spool in there.
Those Peloquin diffs are great, but heavy and unnecc in drag racing.
At 680kg and turbo?... what ever the application,
you will need taller 1&2 gears.
You have close ratio 1&2
then wide gaps between the rest!
Turbo will pull through that OK,
but it would be nice to have better-than-stock ratio gaps.
With the tall 4th gear you are kind of limited to wide gaps,
but if you need to keep that 4.57 diff ratio, I would choose:
4.57 diff
2.82 or 2.90 first gear,
1.857 second,
1.19 (or 1.14 third would be second choice)
0.82,
Even better would be one of Albins
4.125 ratio crownwheel and pinions,
3.111 or 3.333 first gear
1.93 or 2.00 second gear
1.25 or 1.300 third gear
0.89 4th gear.
turboboy - July 21st, 2014 at 10:55 AM
Thanks for the reply Dave
This is a street driven Buggy
With a bit of strip play
The reason Peloquin diff I figure is to help keep it straight
under hard take off
Hp hopefully around 250 ,Ron Lummus recon's 300 but I'm shore he is talking flywheel HP
I really don't want to boost more than 15lb's.
I have never really looked at gearboxes, specially Kombi boxes
So your advice is greatly appreciated
