Does any one know the minimum weight for All Motor class in drag racing,
I have read through the entry details for the Compac Attac and it says cars will be weighed but it gives no minimum weight.
I ahve the compact rules somewhere as a pdf. Will have a look for you.
I think you can still get them from the andra site...
here you go off the ANDRA site
ALL MOTOR – DYO - CLASS REGULATIONS
Class Designations: AM preceded by car number.
The All Motor category is designed for full-bodied cars using original floor-pan and no power adders.
Minimum Weights:
FWD 4-cylinder: 1,650 pounds; RWD, VW air-cooled, stock “Type I” case only: 1,750 pounds; RWD or 4WD 4-cylinder/2-rotor: 1,950 pounds. Full tube
chassis or back half with non-OEM strut mounts/strut tower permitted in FWD only - add 75 pounds; sequential, clutch-less, V-gate or non-OEM
aftermarket transmissions, add 200 pounds. All weights include driver, verified after the run.
Beck ...
you will have to go and get some lead to add the weight
No, I'm fairly fat these days, should be right.
