stuffed generator??
nishii77 - January 6th, 2010 at 03:32 PM
hi just in the last couple of days the generator light dimly lights when i have the headlights on, and if i have my phone charging thru the 12v outlet the headlights get dimmer too. Is this possibly the generator dying a slow death?, or maybe something else?
vw54 - January 6th, 2010 at 04:16 PM
have u check the tension of the vee belt
could be the regulator
how old is the battery as well does it have correct amount of fluid in it
does the earth strap havea good connection to the bodywork
is the earth strap broken between the gearbox and body
