25 minute door cards
esevwbits - October 19th, 2011 at 02:52 PM
was sick of looking at the rip in the passangers door card so picked up $23 worth of vinyl and went out the back for a couple of sheets of masonite to make up 2 new door cards.
a little stitching, some foam and contact came together to make these.
http://i120.photobucket.com/albums/o171/esevwbits/2011-10-14170958.jpg
http://i120.photobucket.com/albums/o171/esevwbits/2011-10-16132644.jpg
dragsters for life - October 19th, 2011 at 04:33 PM
nice i really dig the blue
planning on doin the same sort of thing in the wifes type 3
cam070 - October 19th, 2011 at 05:34 PM
Nice work!
68AutoBug - October 19th, 2011 at 09:08 PM
EXCELLENT WORK
waveman1500 - October 19th, 2011 at 09:41 PM
Very nice, but no door pulls though? How do you close the doors? Just pull on the handle?
esevwbits - October 20th, 2011 at 06:28 PM
Thanks for the feedback :)
Waveman, im still looking for something that looks good for a doorpull. will update once is all complete
matara - October 20th, 2011 at 07:10 PM
Is that Peter still holding his birthday cake ;)
esevwbits - October 21st, 2011 at 06:16 AM
hahah tis steve, tis!
Pumba - October 23rd, 2011 at 07:58 AM
Well done,alot cheaper than the price i got,$150 each door card no pattern on them just beeding around the outside, i was horrified,this is after she charged me $450 for my back seat :crazy:
1916baja - October 23rd, 2011 at 08:40 PM
:crazy:
esevwbits - October 30th, 2011 at 06:10 PM
ouch!
SebastienPeek - October 30th, 2011 at 06:23 PM
Damn they look great!
poe70 - November 8th, 2011 at 08:23 PM
What sort of door clips did you use? I've seen the little plastic xmas trees but not sure how well they would work.
1916baja - November 10th, 2011 at 05:11 AM
You need to get early holden steel clips. Your local motor trimmer should be able to sell you some or at least tell you where to get some.
esevwbits - November 13th, 2011 at 07:59 AM
have wurth door clips. same as what came out originally on the beetle.
Topaz - April 21st, 2012 at 06:30 PM
Hi,
Was it difficult to make? How did you do it, any chance of obtaining instructions for the rest of us??
They look pretty good :)
esevwbits - April 28th, 2012 at 04:26 PM
used a template from the old ones for a size. Cut the sheet of masonite to that size.
acquired the two colours preferred..
worked out a quick and easy design - flipped material upside down, sewed material together.
spray gun of Contact adhesive used for 3mm foam application to back of material.
stitched in a wonky line for aesthetics as per pics :)
drilled holes on outter edge as on originals and window / door handles.
wrapped material and foam over masonite board. Stapled around the perimeter
placed Wurth clips in appropriate areas - ' X ' the door handle and window winders with a razor blade. ( or hole punch if avail )
fit and voila!
rating of 5/10 for difficulty
1303Steve - April 28th, 2012 at 05:00 PM
Good work. I used grab handles from the roof of a 1303 as door pull handles, just drilled some holes in the door and used rivnuts to bolt the handle to.
esevwbits - May 4th, 2012 at 05:27 PM
Top idea,
One of our customers has mk1 golf doorhandles, they look fantastic. The door open pull lines up perfect. ill try and grab a pic..
Joel - May 4th, 2012 at 07:16 PM
That's all that 1300 bugs after 72 had stock anyway, the stock holes will line up.
Mk1 Golf and Lbug used the same door handle/armrests, 76 Beetles too from memory.
ClockworkMonkey - May 4th, 2012 at 08:46 PM
Thats a pretty tidy job!
i wonder if you could do something like that just over the top of a standard door card? or would it be too thick?
esevwbits - May 30th, 2012 at 08:08 PM
id remove the original material, but sure, if your board is in good nick,then by all means use it!
esevwbits - June 19th, 2012 at 12:21 AM
These door pulls are on a friend/ customers car.. I think they are a great idea and incorporate the handle too!
http://i120.photobucket.com/albums/o171/esevwbits/20120606_114744.jpg
