Quality engines
kombiwhisperer - November 8th, 2015 at 11:07 AM
Hi all, Have a range of engines in stock
We specialise in building engine packages to your requirements---
Also run full in house quality control system(you have seen some junk too)
Our warranty is 12 months and real!!! not excuses or blame on you
Full turn key is our preference
28 years experience A-grade mechanics Geoff's Auto Studio 0407968021
kombiwhisperer - December 31st, 2015 at 05:19 AM
New 1776cc in stock
Reco Pobjoy 1915
New 2055 Hydraulic twinport
karmann141 - December 31st, 2015 at 07:08 AM
Hey Geoff,
Thanks again for the Ghia parts and for chatting and showing us around your facility - very impressed. Will definitely come and see you when the L Bug needs a power increase after doing learner driver duties.
Great to meet you.
Cheers.
wombatventures - February 17th, 2016 at 06:27 PM
Hi Geoff,
Do you work on trans as well.
Need an IRS for a 74 super?
kombiwhisperer - March 17th, 2016 at 06:42 AM
Dave Butler 0417 879 220
baywindowbandit - March 18th, 2016 at 03:57 PM
Hi Geoff, do you machine cases to fit bigger barrels? I've got a motor that I would like to re build with a set of barrels and pistons, but need the cases done, as well as the deck height.
kombiwhisperer - March 29th, 2016 at 06:00 AM
Sure, we do them here, or if Dave Butler davebutler10@bigpond.com is closer he does them too(Reedy Creek QLD)
kombiwhisperer - April 1st, 2016 at 07:01 AM
IN STOCK
New 1776 hydraulic cam New heads $4500
REbuilt 1835 STD $3300
NEW Hi-level 2055cc Hydraulic 228 deg cam, Torquemaster heads $6500, Scat crank and H-Beams
Rebuilt 2080cc Type4 Kombi Hyd cam new Heads $6500
REAL 12 Months Warranty, all engines outright and long block with CB Perf. filtered oil pumps
GEOFF 0407968021
