550 spyder + DIESEL?
nathanabbott - May 8th, 2011 at 03:34 PM
Hi, folks. Noob, here. Just bought a Thunder Ranch 550 Spyder & had a bad idea (my favorite kind):
Can you install a modern VW diesel engine (ala Top Gear's "Project Sipster")? In a 550? Has anyone tried?
I'm aware of the many reasons NOT to do it, but is it POSSIBLE? A 1300 lb car + a motor that pulls 40MPGs in a 3000 lb Jetta has to be good for at least decent gas mileage, right? If a watercooled Sube WRX engine, will work, why not a diesel? Tom @ Thunder Ranch told me it could be done... with a little creativity in the motor mounts/half shafts dept.
I'm no mechanic so I reserve the right to be wrong about everything.
wolfgang54 - May 8th, 2011 at 04:15 PM
please go into a room full of mirrors, well you know the rest :lol:
vwjon - May 8th, 2011 at 04:16 PM
anythiing can be done, they drove on the moon didnt they? they throw chevy V8's in the front of beetles, so why not throw a diesel donk in the back of a Porsche?
HappyDaze - May 8th, 2011 at 04:39 PM
You may run into trouble with the height of the engine. Most 550 replicas have a 'flat' engine [mine is a Beck, with a 911T ], so height is not a problem.
Measure the height of the engine that you want, to make sure it will fit.
