WTD: Superbug (1303) radio surround plate & radio mount bracket.
Tim Meier - January 6th, 2021 at 09:33 PM
Hello,
I'm after the attached two items for an L-Bug.
1. The radio plate which goes around the headset.
2. The metal bracket which screws to the metal behind the dash. The headset slides into this bracket.
1303Steve - January 8th, 2021 at 03:59 PM
never seen either in person
Tim Meier - January 11th, 2021 at 07:36 AM
Most likely because they've all been pulled out a good 30 years ago to hack in a modern head set unit!
1303Steve - January 11th, 2021 at 08:49 AM
I bought a little old ladies car a few years ago that had never had a radio fitted.
I'm not sure if you want an original look but I've made a DIN size plate out of aluminium sheet before and a complete cover to stick chequered contact too
AA003 - January 13th, 2021 at 01:27 PM
They were probably never sold in Australia as LNC didn't sell factory radios.
Try here
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D133%2D053%2D313
or here
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=133053313
beetleboyjeff - January 13th, 2021 at 09:08 PM
I bought my L bug 3rd hand in about 1986, and it has the plastic surround part - I still use it.
Tim Meier - January 18th, 2021 at 12:03 PM
Thanks all, might be easier to buy the LHD bit and cut the tab off on the left and try glue it on the right side.
1303Steve - January 19th, 2021 at 05:34 AM
I saw this on Facebook, maybe this guy could make you one
