WTB Factory sliding windows parts
Buzzy - October 9th, 2021 at 04:14 AM
Looking for sliding windows parts for factory fitted windows for 73 bus
vw54 - October 9th, 2021 at 06:01 PM
Where are you at
Very hard to find as there were different makers
1303Steve - October 10th, 2021 at 07:27 AM
I didn't think sliding windows came out until much later, I'm pretty sure 1973 models had fixed glass with flipper windows
Bizarre - October 10th, 2021 at 01:35 PM
Sliders came out from factory in Australian busses in 1977.
What parts are you after?
The latch and other bits if the trim are the same T3/Vanagon
Most of it is available from Gowesty and Van-Cafe
I just rebuilt a set for my 1976
Well worth it.
Buzzy - October 12th, 2021 at 01:59 PM
Originally posted by vw54
Where are you at
Buzzy - October 12th, 2021 at 02:00 PM
thanks folks.
I have a 73 bus and am installing orginal sliding windows. needing to replace the rubbers and sliders to keep water out. not sure of brand.
Bizarre - October 13th, 2021 at 12:45 PM
If the latch is at the bottom front they are original VW
If it is at front side 3:00 or 9:00 o'clock (depending on the side) then they are aftermarket or Brazillian
I got my bits from GoWesty
You will need this bit if you are taking the window out to replace the felt
https://www.gowesty.com/product/sliding-/22666/sliding-window-guide-piece-?v=
or
https://www.vancafe.com/281847723BPACK-p/281847723bpack.htm
The felt seems out os stock at GoWesty ...... was there yesterday, but AVD wouldnt allow me to post :(
Found it at VanCafe
https://www.vancafe.com/281847721-p/281847721.htm
This is my van's windows
https://forums.kombiclub.com/threads/my-bay.58941/page-6
There is a good thread on Kombiclub that has a very detailed write up
