Superbug IRS
jsheppard64 - November 22nd, 2008 at 06:45 PM
okay i know that the IRS comes with 5 deg camber
but for some reason both of my rear suspension is at the same level from the ground and one has more camber than the other. i think it's the rubber bushings that's gone but could there be another problem? also the wheel seems to stick out further on the side that has more camber.
Brad - November 22nd, 2008 at 07:00 PM
check your bushes, inner washers and also the placemnet of the trailing arms on the spring plates.
They do bend though so don't discount it
jsheppard64 - November 23rd, 2008 at 10:26 PM
i think it's the bushes but when i had a look it looks like the whole trailing arm is bent or not sitting in properly when jacked up cos the camber can be noticed even when i jacked the car up and the arm all the way down
