Hi,
I inherited a late model kombi complete front end including steering box and column. I am about to restore a 64 split screen kombi and am wondering if
it will bolt straight in?
Nope..
wont bolt in. only early wide 5 68 bays will. you can make them fit but better to get the early one. M
Thank you for the replies. I will work on the early front end
get & 68 front beam assy, & take the drum wheel-assys off it, then fit late dic-brake assys off the front end that you Have & you will end
up with a "Bolt-In" disc brake front end
Early 69 fit as well, late 69 wont
Use the core for a narrowed beam
